Generally you're told to follow the rule that all feeds must rise and all returns must fall to encourage thermosyphoning.
Is there any reason why you should deviate from this?
I'm thinking if there is only a small vertical distance between the flow /return connections on the stove, isn't there a chance the heated water will attempt to flow up the return - especially as there is more of the return pipework being directly heated through radiation from the stove?
