Hi looks like I've sparked a bit of a debate!
I'll try and answer all the questions:
1) The heat store is an ordinary cyclinder with no coils and is heavily insulated.
2) I've included a better diagram showing the DHW indirect cylinder connected to the neutraliser.
3) The store was added because of the location of the stove and airing cupboard being about 15 feet away.
There was no method of ensuring thermosyphoning would work along the only possible run.
4) I think..... The way the neutraliser works in our setup is.....
All heated water water (gas boiler and wood burner) goes to the neutraliser. All heat requirements come from the
neutraliser eg DHW coil and CH water is pumped from there. This is the full knowledge of a proven
non-plumber!
any road up, I got some X200 and have added it to the system as advised by Tony. The fire's alight and the CH is off and isolated. What I really hope is that the fire will run cooler and not kettle. I guess I need to watch for a few days and see what happens. Fingers crossed!
[code:1]............------------------------------------------------------|
........|---|---|F................................................|
....|...|.TANK..|R..............................|.............|.......|
....|...|.Store.|---------------------------|...|.............|..FE...|
|-------|_______|...........................|...|.............|_______|
|...|....Loft...............................|...|
|...|.......................................|.|.O..|..Heat.Store.Pump......|------------|
|...|.......................................|.|____|.......................|............|
|...|F......................................|...|..........................|.Gas.Boiler.|
|R......|.......|..........................|............|..................|____________|
|-------|.......|...............-----------|.Neutraliser|.....................|..|..............................
........|.Stove.|...............|..........|............|---------------------|..|
........|_______|...............|.....|----|____________|________________________|
.......Dining.Room..............|.....|........|..|....Airing.Cupboard
.............................|..\/\/\/....|....|____________|.RADS.......|
.............................|.DHW.TANK...|.................|............|
.............................|____________|.................|____________|
...........................................[/code:1]
non-plumber!
