On a job at the moment where I have been given a free hand to sort everything out, to the book, while the client is away on holiday.
These are my findings so far...
25mm2 tails with a couple of strands cut in order to make them fit into the old wylex standard board, The 16mm2 G/Y was in a similar state.
Tails run very much out of zone, from the looks of it, because the installer did not have a long (600mm) 25mm2 masonry bit.
Lets joint this ring final with 5A blocks. Found 3 instances of this so far.
Burnt out dimmer, amazingly, it was still working! Causing the MCB feeding it to buzz a bit tho...
My mate on a very slow day on site.
