If you drop it in the bath then the risks you face can't be mitigated by any SMPS design features.NONE OF THIS HELPS IF YOU DROP IT IN THE BATH.
All chargers are galvanically isolated by means of a transformer as required by EN60950.Most chargers and similar devices do not contain such things, because if the did they would be much larger and more expensive.
Only the ones that conform. ESF (I think it was) found some that only contained a capacitor!All chargers are galvanically isolated by means of a transformer as required by EN60950.
EDIT: and a rectifier, of course!
I suppose there is no real reason why you should not have a SELV socket in a bathroom? It would need to be 12 volt or less, which would fit nicely with USB. I have just read BS7671:2008 and I can't see anything to stop it, unless something added to amendment 3?Hmm, I'm off to design a shaver socket with a built in USB charging port...
Many of the low cost SMPS units have a high frequency isolation transformer with it's windings inter wound on the core with only the lacquer insulation on the wire separating mains from output.
