- Joined
- 27 Jan 2008
- Messages
- 24,927
- Reaction score
- 2,884
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
Found the bung, found the 6.3 hex drive on end of motor, but can't find how to release the brake. Been parked centre away from charging station needs winding back onto charging station, but can't find how to remove brake.
Since fitted 2009 I decided a new set of batteries would not go amiss, so fitted new batteries to get it off the stairs. However should it happen again then want to know how to crank back to charge point.
Odd but charge contracts are 27 volt AC not DC clearly turned to DC in the chair. Fitted new batteries measured voltage 25 volt wound to charging point remeasured 26.2 volt so clearly is charging. But old batteries measures 3 and 5 volt so no wonder why it did not work. But not a clue how they got that discharged!
