- Joined
- 27 Jan 2008
- Messages
- 28,160
- Reaction score
- 3,416
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
I think the battery idea is power cuts will not cause them to fail. However it is also plain one risk assessment does not fit all. It's all well and good saying if the battery is flat flash a warning but for it to stop the lift mid travel is not really what is wanted. Also having an array of LED's to show status is not very helpful when the array has a plastic cover so you can't see them.
OK after finding the circuit diagram and studying what happens I was able to work out it was a battery fault. But a simple transparent window and a list in the instruction manual could have made it easy and I could have rung up the social services and told them exactly what was wrong rather than simply saying it will not work.
More to the point rescue services could also see at a glance what was wrong and it would not be rocket science to have an emergency battery socket so the occupant could be safely brought to the ground floor without needing to transfer on the stairs to a rescue frame.
