If using a cement based adhesive onto plaster you need to use a primer or the two can react and not provide a proper bond. http://www.biscem.co.uk/downloads/Biscem-TilingOntoPlasterAndRender.pdfyou wont need any primer
If using a cement based adhesive onto plaster you need to use a primer or the two can react and not provide a proper bond. http://www.biscem.co.uk/downloads/Biscem-TilingOntoPlasterAndRender.pdf[/QUOTE]you wont need any primer
the waterproof adhesives have a "built in" primer so you dont need to prime. no reaction!
i use weber wr, straight onto plaster never ever had a problem.
what number on this list? if its long i should be right down!
check your pms too ya old g*t
