M
manchestertiling
This is a topic that pops up a lot & always gets a lot of input re thickness issues Kev, personally I would think that adding noggins etc would be sufficient for 18mm, securely fixed at 300mm centres. Check for movement once secured! T&G add's its own strength by itself being t&g spreading the load across the floor. Thing with any timber flooring/sub flooring is your always going to be susceptible to movement so my advice is secure thoroughly.
Sealing wise Kev, you only need to seal the underside & edges of the ply to stop moisture ingress from below, ply in itself is made by a laminating process using bonding agents. Use flexible power adhesive & flexible grout.
Seal the PB with an acrylic primer like BAL APD
