Tiling Shower Cubicle
2 May 2007
Hi
I have a question regarding tiling the inside of a shower cubicle when i get to the internal corner.
Do i butt a tile against the wall, cut the adjoining (right angle) tile about 2mm short and then use sealant?
Bit confused about this one
Lee
basically yes. it doesnt need to be dead tight to the wall, as long as the other tile covers it.
usually a shower would be tanked or otherwise waterproofed, so tiles are only secondary water resistance
Run a bead of matching silicone down the corner of adjacent walls rather than use grout which will crack if you get any differential movement.
The necessity for tanking will depend on the tile base. If it’s plasterboard of any sort then definitely if you want it to last any length of time but if its waterproof tile backer board then a quality trade waterproof flexible cement & grout is usually sufficient.
Its tanked already.
Got another problem now though and this is a really good one. At the moment i have the hot/cold pipes sticking out which the shower (Mira) attaches to.
One these there is a cover that goes over them which goes on before the shower unit itself which hides these pipes. The issue i have is that these are about 5mm too short.
Can you get longer ones?
