Building Control confirmed that it is indeed exempt. From the horses mouth:
I specifically referenced the closeness to the boundary and the type of construction. The particular BCO has visited the site twice so knows the project well.
For those interested in my original plans, there's a bit of information on 'Pole Barn' or 'Pole & frame' buildings can be found below.
"Pole construction is considered one of the most economical ways to build, and, from a builder's standpoint, it's one of the simplest"
http://home.howstuffworks.com/home-improvement/construction/projects/build-pole-barns.htm
"Post & frame barn construction is simple and does not require a lot of knowledge to build one."
http://www.barntoolbox.com/pole-barns.htm
I think I'll be following Jason's stud wall on bricks method though (cheers Jason!)
I can confirm that as long as the floor area doesn’t exceed 15m2 and its detached and it will not be used for sleeping in then it will be exempt from building Regulations. So based on the below information you are fine to go ahead.
