Alternatively:(in the following, use [ and ] where I have typed { and } )
1... type {url=xxxxxx} (where xxxxxx is the url of the link)
2... then type the text you want to appear, such as "click here" (without the quote marks)
3... then type {/url}
It is easier - but, beware, at least in my hands it doesn't always work, or work as one expects - hence I tend to use the 'less simple' method.Not only easier but better chance that I will remember that Cheers.
That's a good point. Although, at first sight, it is inefficient and wasteful for most of the heat from the storage heaters being output during the daytime when, as is common, the house/flat is unoccupied, the fact that the building would get pretty cold by evening if this is not done means that a lot more heating (with much more expensive electricity) might be required in the evening. However, as you imply, if the house can be kept warm with 'cheap electricity' during the day, then only a fairly modest top-up (with much more expensive electricity) will be needed during the evening.I’d stick with the storage heaters and just have them on low and use a couple of good quality space heaters. my first flat had this set up and i used the storage heaters with the damper on max and then brought it up to temp as needed with electric fan heater or electric rads. much easier with heat in the infrastructure
Yes, it's quite doable. Pick a timer, add a large relay/contactor, put the supply to the second CU through that - OR put each outgoing circuit on the CU through one pole of the contactor (that's how the offices I used to work in were done).A timer on the whole consumer unit would also be interesting but I doubt that this is possible.
I think those who are out all day already try to achieve that - by leaving the shutters/whatever closed during the day and open them when they get home, but still find that ther's not enough heat available in the evening. I suppose there's a limit to how well insulated the bricks can be without the heaters becoming unacceptably large.I don't suppose anyone does storage heaters with motorised output controlThough I suppose it would be possible to DIY it. With that, you could keep much of the heat in during the day and let it out when needed (stat/timer combo).
Many moons ago, a friend of mine tried that, and I think ended up concluding that one would need massive tank(s)/cylinder(s) and many immersions for it to be an even half-viable system. Don't forget that a standard immersion is 3kW, but a CH boiler can easily be ten times that.Or going a bit OTT, a large storage tank with immersion heater(s) on E7 night, and feeding a conventional wet radiator system.
Quite so. Another way of looking at it is to think about (or estimate by calculation) how big a cylinder one would need to store all the hot water generated by a CH boilier during a period of, say, 6 or 8 hours of (intermittent) operation.Thanks for the thoughts. A 125litre cylinder will heat up (6 kw) in 70 mins therefore if you used this as a heat store you would theoretically have a 6kw output available for 70 minutes. Of course once it had cooled below 50 degrees extracting further heat to warm a room would be difficult so it would actually be useful for rather less than 70 minutes. This gives a pointer as to the size of storage that you would need to run a conventional heating system.
Indeed. As I said, whilst it is theoretically possible to insulate a storage heater so that it retains heat for as long as one wants, in practice they would probably become far too bulky if they were insulated as much as 'evening heat users' would like.I did look at the Elnur heaters before and what troubles me about them is that they do not give any figures for heat loss when output is off. Her existing heaters are kept off untill she comes home from work but she often wakes in the night to throw off a duvet when they start heating up because so much heat is emitted through the case rather than the grill.
Do you know how old the storage heaters are?she is at work all day (when the house is warm) and comes hometo a cold flat in the evening.
If you say so.That second link from motorbiking also has a helpful "storage heaters vs electric radiators" page which has helped reassure me that she is in fact making the right choice.
