D
durhamplumber
But only after a week in this case...That is mad Harry.Not quite reconnecting a plug fully would do it and generate a fault.
No it doesn’t, it’s the highest percentage of likelihood of the failure.
The old pcb is the customers property..Leave it with them.So what happens to this suspect PCB if the gas technician takes it away..... In some industries a suspect PCB would be destroyed on site to prevent it accidently re-used.
That is where on the job experience counts.So you are saying Vaillant ought to have it at the top of the list? F61 indicates a gas valve failure, other possibilities are a wiring fault or PCB failure. Maybe Vaillant ought to mark an F61 as a PCB failure perhaps?
I’m saying the information is there available, interpret how you will, the bar chart they provide is a bit of a giveaway. I work on these day in and day out, I know what I’d change for every F61 fault, without checking any of the other.So you are saying Vaillant ought to have it at the top of the list? F61 indicates a gas valve failure, other possibilities are a wiring fault or PCB failure. Maybe Vaillant ought to mark an F61 as a PCB failure perhaps?
Some lads leave the old parts near the boiler so that any further visits , it is seen what has been changed, personally, I ask the customer if I can put it in their bin and mark up on the service record what has been changed, if they want to keep it great, I hate taking away scrap that I have to dump legallySo what happens to this suspect PCB if the gas technician takes it away..... In some industries a suspect PCB would be destroyed on site to prevent it accidently re-used.
How much is your estate agent, solicitor charging you ?How much is the house going for?
Andy
Trouble is, most can do without a radio and manufacturers know thisdevice such as a radio costing around £30.
