the hour hand on our cuckoo clock has come loose, so it hangs at
6 O'Clock, any cuckoo clock enthusiasts? need a solution.
A little dab of "cuckoo spit"..
Roughcaster.
http://www.ticktocktony.com/repairtips.htm10. The hour hand has become loose and is constantly pointing at 6! This is a common problem and is very common on cuckoo clocks, however the fix is simple. The hour hands are held in place on a friction fit bushing to the hour pipe, so just push the hour hand in place and then move it to indicate the correct hour. On an English or Scottish grandfather clock this is not the case. Mostly the hour hand is screwed into place. If you have this problem and own an English and Scottish Grandfather clock then you should call a clock repair specialist.
Matron!If it is just a friction fit, lightly squeeze the bush, then refit.
he's still waiting to come online on the hourDid you get sorted WDIK?
That one of them super plastics is it?Get a plastic plastic clock from IKEA for a couple of quid and glue it over the face of your cuckoo clock
A sort of Plastic Fantastic Fetish there dex?
