Yes.Am I right in assuming that I would need to add the suppressor to only one lamp fitting?
Kind Regards, John
It is, but it may also be effective in those cases when low-watt lamps are glowing/flickering (when 'off') due to the electronics of a device using those lamps as a path to neutral for its power supply.I am not sure how the "suppressor" got introduced into the thread. It is designed to provide a sink where there are problems with low-watt lamps (like LEDS) from glowing di=ue to induced voltages.
It's not the OP's fault - it's the fault of me (and maybe others). I have acknowledged that he may well not need the suppressor but, as for 'a problem you don't have', as I've said, the reviews of this product do not indicate that such will necessarily be the case.I have no idea whhy you are going down this route. It seems that you are worrying about a problem that you don't have.
As I've said, the specs of devices like this are a bit unclear/ambiguous. They don't usually (and not in this case) talk about a total fluorescent load of at least 17W. As I said, it could be that there has to be at least one CFL which individually is ≥17W. The OP will discover when he tries and then, as you say, can decide what to do if he has a problem.... Go back to the maker and get a refund if the spec says it works on fluorescents of 17watt minimum and it doesn't.
Kind Regards, John
(Of course, should flickering occur, yet another option occurs to me: to substitute one 18W fluorescent for a 10W!)
But the switch needs AT LEAST 17watts. IIRC, 10 is less than 17….
I'm thinking of buying one of these:
http://www.amazon.co.uk/Electronic-Wall-Switch-Timer-Day/dp/B0018S13PO
The spec. says that the minimum load must be 40W resistive or 17W fluorescent (and not suitable for LEDs).
I want to use it for seven 10W fluorescent outdoor lamps (wired in parallel, of course). Am I right in assuming that this would equate to 70W, and that the timer switch would be suitable?
Thanks.
Are we having a communication problem? I do not understand what you mean.
When this all started you saidHi,
Thanks.
And I replied that as 70watts was bigger than 17watts you should be OK.
So you should be OK. End of.
Or have I missed something
I think you are forgetting some of the story, and also misunderstanding what the OP has written above.But the switch needs AT LEAST 17watts. IIRC, 10 is less than 17….(Of course, should flickering occur, yet another option occurs to me: to substitute one 18W fluorescent for a 10W!)
That's good to hear, and we thought that it might be the case - although it's apparent from some of those reviews that some people's experiences have been different. I certainly wouldn't put any money on, say 17 x 1W lamps being without troubles!Fortunately, there was no flickering of the outdoor lights (when off), so it appears that if the TOTAL load exceeds 17W (fluorescent) the switch is suitable.
You're welcome. I'll keep my eyes closed whilst the flak flies aroundAnyway, thanks again for your advice, JohnW2. (* I know I'm going to get shouted at here, but I discovered this by using one of those detested screwdrivers with the LED lamp!)
