1st thing to do is clear out all your temporary files, tool of choice is ATF Cleaner, it is free and you do not have to install it. Download and instructions here (Windows XP, 2K, 2003 & Vista ONLY)
* NOTE : If you would like to keep your saved passwords, click No at the prompt.
-- Click on ATF-Cleaner to run it
-- Where it says Select Files To Delete, Check the Select All Option
-- Click Empty Selected - > OK
If you use Firefox browser, do this also:
* Click Firefox at the top and choose Select All from the list.
* Click the Empty Selected button.
You could also Boot into Safe Mode with Networking, see if the issues are still present running that way.
As soon as your computer starts up keep tapping the F8 key and, using the arrow keys, select Safe Mode with Networking, then press the 'Enter' key.
Did you get another antivirus installed?
Also, as you have ZoneAlarm firewall installed, check that the Windows firewall is actually turned off. Start -> Control Panel -> Security Centre -> Windows Firewall, ensure that it is OFF.
dave
dave
