double post
im not having a pop just saying what i think im sure you will make a good plasterer one dayit's only the second ceiling I've skimmed.Promise to do better.
looks much better m8 and you done it with a crappy trowel as well?went back and smoothed it all out
Out of interest if a pro was doing a job like this what size and make of trowel would he/you use? And what about a big float trowel (20"long?) Is one of these worth having?
marshalltown, and tyzac are the 2 prefered makes, i use mt, i did buy a tyzac but never used it it felt unbalanced to me, but it all depends what yor used to, i know someone that uses tyzac and he feels the mt is unbalanced i think the handle is set further back on the tyzac, as for size a 13in is a good size to start with, ive been with other spreads and they use the big trowels 18in+ on ceilings but they are experienced, the biggest i use is 14in, if i were you i would go for a 13in and as you get better you can then get a bigger one later if you feel the needCheers for the encouragement.
RST carbon steel in actual fact @ £9 from T**lstation. Fresh out of its wrapper as well and not broken in am afraid.
after seeing this vid im going to give it a go, but those spreads are using it for the final trowel it looks like, you say you use it just to flatten in the first coat? also looking on the refina web page it says used in conjuction with the sponge float which i used to do a lot of, im going to get one and give it a bash, ive just got a question or 2 if you dont mind mich so i get this right first go, so is it lay on 1st coat flatten with spatula- lay on second coat flatten with spatula - trowel up then cross trowel with the spatula? http://www.youtube.com/watch?v=Ur3sY1sD2rIFor the last couple of years I have flattened in the first coat with a light
s/steel 18'' spatula
after seeing this vid im going to give it a go, but those spreads are using it for the final trowel it looks like, you say you use it just to flatten in the first coat? also looking on the refina web page it says used in conjuction with the sponge float which i used to do a lot of, im going to get one and give it a bash, ive just got a question or 2 if you dont mind mich so i get this right first go, so is it lay on 1st coat flatten with spatula- lay on second coat flatten with spatula - trowel up then cross trowel with the spatula? http://www.youtube.com/watch?v=Ur3sY1sD2rI[/QUOTE]For the last couple of years I have flattened in the first coat with a light
Steve - I put on 1st coat with trowel, the flatten with spatula (pulling from wall into middle all round, then just do the bit in the middle)
Lay down with fesh gear, trowel up with trowel no more spatch.
I can see it working with spatch instead of first trowel , while the gear is soft but I can't see how you'd get it trowelled up with a spatch- especially as it goes off when you need a bit of 'bite'
neither could i mich thats why i asked if you trowel it up b4 crossing it using the spatch, so on that vid they have trowelled it up and then they are giving it the final cross trowel with the spatch you think?either way im going to get one and give it a go, take a look at this link if you havent already http://www.refina.co.uk/pdf_tools_09/B_Superflex_Spatula_2009.pdfI can see it working with spatch instead of first trowel , while the gear is soft but I can't see how you'd get it trowelled up with a spatch- especially as it goes off when you need a bit of 'bite'
lol that suit looks a bit over the top doesent it? he looks more like a bakerSteve - Is the chemical warfare suit optional?
