- Joined
- 17 Aug 2010
- Messages
- 2,889
- Reaction score
- 507
- Country
Let's hope the OP hasn't been waiting all weekend for the outcome, and earthed it yesterday.
It seems not, per the message he posted 2 minutes before youLet's hope the OP hasn't been waiting all weekend for the outcome, and earthed it yesterday.
Been pulling the stuff out of a cottage all week - a pita!I will not be removing the conduit, as anyone who's had the "privelege" of working on masonary walls plastered with black mortar knows, as this will make black dust that will covering everything for ages.
AmateurFiFi";p="2853637 said:Many thanks to all who've offered an opinion.
No photos available unfortunately.
The lighting circuit is RCD protected and the conduit is currently - and will remain with the T+E inside it - in a safe zone.
Best wish with your project.
Lxboy
I think you're actually the only person to have explicitly made that point up until now - but, yes, I would imagine that most people would agree that if none of the conduit is exposed, then it clearly can't be an exposed-conductive part, and therefore would not need earthing. As for the risk of drilling/nailing into it (after it had become live due to a fault), siting in safe zones is meant to minimise the risk of that happening, and RCD-protection there even if someone does it. so, yes, I would agree that ...... I believe we all agree that removing the possibility of touching the conduit will negate the need to earth it.
...is a very reasonable option.If the conduit is to remain in the wall then as I said earlier cut back the exposed bit in the loft and provide some form of protection/covering for the remaining bit - this can be a suitable block of wood or even a plastic junction box
Why?Metallic conduit is always considered an exposed conductive part.
How can something which is not exposed be an exposed-conductive part?Metallic conduit is always considered an exposed conductive part and must be earthed.
Yes, but you need to read the rest of the thread as well. The suggestion that it it could, in some circumsatances, be regarded as non-exposed (and therefore, to my mind, not qualifying as an exposed-c-p) arose in relation to the suggestion that the part in the loft could be cut off and the end covered with something to make it non-touchable. Would you then still regard it as an exposed-c-p?It''s exposed in the attic read the OP.
Fair enough - but, as I asked, what would you do if (as riveralt suggested) the situation was changed such that there was no exposed conduit - would you still want to earth the (non-exposed) conduit?I would just do what any qualified electrician would do and earth the exposed conduit.
