Not a bad shout, I will ask around at workDo you know anyone, with a drone, fitted with a decent camera?
Agree I need to finally get the manhole cover moving, that is certainly on my to-do list this weekend.Sounds like a 1/2 blockage & you really need that manhole cover off. It will give you the opportunity to rod both ways up or down the soil pipe.
Partial blockage may lead to gurgling but not to suction of toilet u bendSounds like a 1/2 blockage & you really need that manhole cover off. It will give you the opportunity to rod both ways up or down the soil pipe.
Well not a drainage engineer as such but spent working life designing sewage treatment works getting flow from inlet to river discharge through various sized gravity/pumping mains along with all the necessary supporting infrastructure, with a bit of mains drainage and potable water works thrown in along the way. Probably why I try and analyse things based on hydraulic/ mathematical principles but keep an open mind on how others see things and if need be learn from their experience."Every day is a school day"I didn't know that you are a drainage engineer Dereekoo.
Andy
Well, clearing manholes on a daily basis, when a customer calls me and tells me that all the water in their toilet has gone, I ask them to lift the nearest manhole and every tme they tell me that it is full.
I'm still trying to work out the logic, but I have an issue with my upstairs WC on occasions, (too much paper and it'll block solid), which requires a suitable prod with a plunger to shift. When the blockage goes, and the pan empties, it does cause some gurgling in the adjacent shower, which is connected into the stack at a suitable point below the WC junction. The stack is vented.I believe you were being asked to explain the mechanism, that would draw the bowl water out, from the bowl, due to a downstream blockage - assuming the vent was working???
My first thought was slight suction, as the plug of waste and water fills the stack and pulls the air behind it, but then the stack is open to atmosphere, top is clear, so no reason why it shouldn't allow free passage of air behind the water.
Or during normal operation of the bowel a plug of water is projected into the soil pipe in a semi controlled way depending on how fast the cistern discharges with lots of air injected into it at the same time which prevents a suction of sufficient magnitude developing in the soil pipe enough to cause any issues with the shower trap, suddenly plunging a large solid mass of water/debris down the soil pipe creates a suction (or air pressure wave) just large enough to have an effect on the shower trap. I should imagine the difference between the parameters affecting the shower trap are quite small a bit like blowing down a straw into your coke and causing bubbles. We need some input from an experienced drainage engineer ( aka plumber)How about - shower entering below the toilet entry, two plugs of material, gap between and the two plugs acting like pistons. The first one will accelerate quicker than the one above it, forming a slight vacuum, between them. The gurgle, being the vacuuming of the shower trap?
