I'm in the process of refurbishing my bathroom and I wish to turn my toilet onto the other wall (at a right angle)
It's on the ground floor so at the moment the soil pipe comes up out of the floor via a pan connector so I'm intending to run this on the surface and box the pipe work in,
If fittings are available I was going to turn the existing pan connector 90deg attach a length of pipe (about 18") then a elbow then another length of pipe (about 24") then a new pan connector.?????
I'm not sure if this is the way to go or am I barking up the wrong tree
Or is it possible to get a soil pipe to connect directly into the existing waste where the pan connector is now I'm not sure if this is iron or clay as I haven't pulled the old connector off yet
Advice would be appreciated
