Hiya,
I'm installing a new toilet and having problems with the plastic connector between the wall outlet and the toilet pan spigot.
I'm using a MACFIT 20mm offset connector, from toolstation
http://www.toolstation.com/shop/Plumbing/Pan Connectors/Macfit WC Connector/d20/sd2887/p55280
Because the wall outlet is a little higher than the spigot on the pan.
I've tried a couple of these now, and every way I try there is a slow leak at the bottom of the connector against the pan. I've tried attaching to the wall outlet first, then pushing the toilet pan against it to connect, and also tried attaching the connector to the pan spigot first, then pushing the whole lot up against the wall into the wall outlet. Everything seems fine when I connect the water and flush, but overnight there is always a leak and a small puddle on the floor behind the toilet. It seems to be coming from the pan side of the connector rather than where the connector goes into the wall outlet.
I know its difficult to describe exactly my set-up here as you wont be able to see the type of toilet i'm using or the rest of the plumbing, but I'd just like to ask if there is anything i'm obviously doing wrong or any suggestions that people can offer me. Silicon sealant? Am I using a poor quality product that's prone to leaking? (there were cheaper options at toolstation - I went for the more expensive version)
Its really frustrating... i've done lots of googling on this and it seems that people have very few problems with these connectors compared to other common plumbing problems - you simply lubricate with a bit of water then push them on to the pan spigot! Job done. Or at least it should be! Help!
Many thanks
Tom
Many thanks
Tom
