Err no they didn't. Common sense should tell you that if it takes a modern cremating oven two hours to burn one body with a burner that looks like a jet fighter afterburner, then to burn two will take four hours and three will take six hours. Putting five bodies in an oven designed to take one body (they don't fit btw) would probably stop the oven from working and put the thing out. Also, the records for the amount of coke used at the camp are available - and nowhere near enough went to that camp to burn millions of bodies. If we can't do it today - then they surely couldn't do it in a wartime camp. Aren't you a structural engineer? Well why don't you understand the first thing about science?
It's not the same as a modern situation. The majority of the bodies they were dealing with were skin and bone with virtually no fat and very low levels of water, typically less than 50kg or 60kg. They also weren't concerned with decent treatment of the bodies. The Topf and sons ovens were also industrial types originally designed for large animals and adapted for human use. It's also recorded that many bodies were under cremated and archaeologists have specifically commented on that fact. So 90 to 120 minutes is viable and I see no technical problem with that.
You still haven't addressed the contemporary records. Why would Topf say the capacity was thousands per month? Why did they need 52 ovens? Why did they need over 800 stokers? That's 16 per oven. If you were generous and said four per oven that would be three 8 hour shifts per 24 hours. All these facts from different sources confirm the figures. The German soldier who wrote the report knew nothing of Prufer yet their reports, made at different times, for different reasons, concur.
You should do some more research mate, according to the "records" no more than 38 of the 52 ovens were operational at any one time, there were periods of idleness recorded as well as breakdowns.
The Topf ovens were basic coke fired models if you look at some of the original photos of these ovens you can see cremation urns stacked beside the oven, these were for the ashes of the individuals who were cremated, most of what you have posted above is untrue,
the claim that you can somehow use human corpses as fuel to cremate other corpses is absurd.
The claim that over a million people were cremated using the 52 Auschwitz ovens doesn't stand up, according to Topf each oven was only guaranteed for 3000 cremations and that is with proper maintenance, regular cleaning ect, so do the sums yourself.
You should also look at the sources of your information,
all this stuff about using thin bodies as fuel to cremate fat bodies comes from the same sources that put up the "4 million died here" sign at Auschwitz.
As for the Archaeologists who commented on the fact that some bodies were under cremated , who were these Archaeologists and did they ever see these bodies in person and if they did why didn't they take hair or tissue samples to have them analysed for cyanide poisoning.
