joe-90 said:So says the guy who's country squanders 25% of the worlds oil.
joe
mlb3c said:joe-90 said:So says the guy who's country squanders 25% of the worlds oil.
joe
Just 25%????....is that all?? I would have thought it was a lot higher than that........hmmm.....the air con feels good now
Probably end up being a moron like youAs the price of crude oil climbs ever higher - you'll stop laughing shortly.
Waddya gonna do then?
joe
johnb80 said:Probably end up being a moron like youAs the price of crude oil climbs ever higher - you'll stop laughing shortly.
joe
I'm actually trying a CHP plant on a small scale at home. I'm using a 3 cylider Kubota diesel engine, it has a CAT on the exhaust to clean up the emissions, furthermore I run it on Natural Gas. First trials look quite promising 20 Kw of power available, virtually silent and I suspect sufficient heat to heat the house in winter time.
During the summer i.e. the last few weeks by running the pump for my underfloor conservatory heating I have been heating my hot water by solar means.
So, assh*le, I am doing my bit but I do like to be comfortable.
Regards - Jack
P.S. Before anyone jumps down my throat saying you can't run a diesel on gas...... YOU CAN.
just a quick one. portable air cons or one with only one outlet are not as efficient because the large amount of air you feel on the hot outlet side, being pumped outside, is drawn from the same air inside the room that you have just cooled and is therefore being replaced with warm air drawn in from outside of the area being cooled
How does the water stay in?My endless pool helps
