What do you mean "drops some fuel"? It’s diesel isn’t it? Any fuel dropped won’t just disappear.
So you went to quick fit again?
After your first trip I would not have gone there again...
There really is nothing that Kwik-Fit could have done to have caused that.
You said in your first post that you took the car to kwik-fit to investigate a noise under the car which happened to be an old clamp.I DIDN'T TAKE IT IN FOR AN EXHAUST CLAMP !!!! I SAID IN THE THRE3AD I REPLACED THECLAMP AND THAT THE CLAMP WAS NOT THE CAUSE OF THE NOISE !!!!!!
The fact that ALL injectors go open circuit is the key for me.
Just looked at wiring diagram and they are all seperate feed and returns to ECU. As said in a previous post the fuel then would return through leak off pipes which i suspect are leaking which is where the fuel is comoing from.Maybe the ECU is goosed? I'd imagine that would be a fatal blow on this vehicle.
Probably, but as the leak-off pipes are in constant use the entire time the ignition is turned on, engine running or not - then why intermittent fuel spill rather than constant? An high pressure leak would be even more constant, even more obvious and the fuel at such high pressure, would be squirted all over the engine compartment - so likely not an HP leakage.
Both the electric pumps(s) and the HP mechanical pumps provide much more fuel than is needed to the injectors. Surplus fuel leaks out of the injectors, at low pressure, via the leak-back pipes, via a fuel cooler, to the fuel tank.
Yeah but it appears that the injectors are shutting at the same time which will build pressure for the leak off pipes.
The leak off pipes are completely dryJust looked at wiring diagram and they are all seperate feed and returns to ECU. As said in a previous post the fuel then would return through leak off pipes which i suspect are leaking which is where the fuel is comoing from.
