You are quite right, it isn't.There's more than one way to skin a cat, but this ain't one of them.
But it is a way to do 2-way switching.
You can wire 2-way switches with only 2 cores and an earth, provided that you have a separate neutral wire available to the lamp. This is very common in older setups, although no longer recommended. See the first 2-way diagram at the link. The second 2-way diagram shows the recommended 3-core + earth wiring.
Reactive push and aBAS, due to your usual criticism of my posts, and your obvious agreement of every word of the above quoted post. Please explain why it is "no longer recommended" to use the singles method for 2 way wiring. And why the "3-core + earth" is recommended.
Also can you explain how this works "You can wire 2-way switches with only 2 cores and an earth, provided that you have a separate neutral wire available to the lamp."
Have a nice day
Or an electronic dimmer with multiway switching using reactive pushes, i.e. lightwave RF or Varilight. Only two wires required exactly the same as mechanical time switches.Thought the 2 wires in the bottom switch hinted at that but thought would just check with some more knowledge people.
Looks like it might be the timer switch option.
It is nothing to do with the neutral.You can wire 2-way switches with only 2 cores and an earth, provided that you have a separate neutral wire available to the lamp. This is very common in older setups, although no longer recommended. See the first 2-way diagram at the link. The second 2-way diagram shows the recommended 3-core + earth wiring.
No.Assuming all the black cores are switched lives, isn't the quick fix just to swap the wires in the top switch? Do you have a picture of the ceiling rose wiring?
Have a nice day
I don't think so - it's only a neutral after the load.Is it just me or is that drawing misleading, at first glance it looks like a neutral at the switches
No, sorry I forgot the cross.and is that the proper symbol for a lamp.
Not a problem -Apoligies EFLI if its your drawing
What do you mean by how? How else could it be?EFLImpudence, the problem with your description and drawings is, you have no idea how the lights are connected to the switchline.
There are only two cables at the switch.They could all be at one end as you have assumed, or they could be taken off at each floor level.
If you are finding that criticism is usual, then think on about that that must be because it is usual for your posts to deserve criticism.BAS, due to your usual criticism of my posts
If you think that is obvious then you need to return your thinking part for a refund or a replacement, as yours is not fit for purpose.and your obvious agreement of every word of the above quoted post.
So - you don't understand something written.Please explain why it is "no longer recommended" to use the singles method for 2 way wiring. And why the "3-core + earth" is recommended.
Err... Remind me who wrote that?Also can you explain how this works "You can wire 2-way switches with only 2 cores and an earth, provided that you have a separate neutral wire available to the lamp."
To be honest I was confused when you said this, though Its not hard for me to get confused.You are quite right, it isn't.
I could explain why twin&earth is not recommended as the wire between the 2-way switches, since I wrote it, but seriously do you not know?
I don't either, what's wrong with using t&e in a 2 way switching situation?I could explain why twin&earth is not recommended as the wire between the 2-way switches, since I wrote it, but seriously do you not know?
I agreed with Watson that method #2 was not a way to skin a cat.To be honest I was confused when you said this, though Its not hard for me to get confused.You are quite right, it isn't.There's more than one way to skin a cat, but this ain't one of them.
