Towel rail too hot
Well I would think you always need some way of regulating heat to within a safe level.
Ideally a thermostat in many instances.
If the architecture of an assembly and the situation it is used in will always ensure excess above this level will dissipate then fair enough but otherwise some kind of stat type system must be used especially with something intended to deliberately add heat as part of its basic function
Dimplex used to make a rotary stat, a bit like a dimmer. Do they still?
Good question there.
I`m sure some of the forum members would be up to making one too
Do you mean a wall stat, or like a pipe stat?
I have some thermal cutouts, but they are intended to go inside an enclosure.
