I still have a 32 year old FS Baxi 24KW, so obviously non-condensing, and doesn't modulate at all.
I've tried my thermostat on TPI for the first time, to try minimise the overshoot on the standard 0.5C hysteresis setting. Minimum 6 cycles per hour on this thermostat, only other choice is 9CPH. In successive ten minute cycles the boiler ran for 3 minutes, 1 minute and 1 minute. The return temperature never got above 30C.
Bearing in mind previous suggestions not to run these boilers at low temperatures, I'm assuming this can't be good for my boiler? Is there anything to try to get it to run longer. Usually a minimum nine minutes is needed to get the return above 45C.
Pity it doesn't have 3CPH. Basically, TPI too accurate, and hysteresis not accurate enough.
EDITED to clarify: It was the return temperature which never got above 30C. I had originally written flow temperature. Changed above to avoid confusion.
