I complained to the planning department because my neighbour has allegedly transformed his property which was a block of flats into a single dwelling house only to get permitted development right. In the report of the planning department it is stated that the only alteration made to this property to allegedly transform it into a single dwelling house has been the removal of the panel of two internal doors.
I complained to the planning department because there have been no permanent alterations e.g. no fixtures like kitchen and bathroom removed. I complained also because the removal of the panel of the two internal doors without their frames could not be considered as permanent alterations.
I complained also because the way this property was built means the removal of the panels of these two internal doors means that there is no door between the garage and the living parts of this property and as a consequence this property could not be used as a single dwelling house because building regulations because of the exhaust gas from the car in the garage going into the living parts of this property
The planning department told me that t is not necessary that fixtures like bathroom and kitchen are removed to transform a block of flats into a single dwelling house
I am surprise by this reply. I do not understand how a block of flats could be transformed into a single dwelling house without any permanent alterations having been made for example it is easy to put back the panel of two doors if their frames have not also been removed
Moreover after waiting for several months finally the planning department has also replied to my accusation that this house could not be a single dwelling house because there is no door between the garage and the living parts of this property by telling me the following
“In your email you state that the property could ‘not be a single dwelling house because of Health & Safety Regulations because there was no door between the garage and the living parts of this house’. When the Local Planning Authority are considering the lawful use of a property we can only apply planning legislation (e.g. Town and Country Planning Act, General Permitted Development Order). A breach of other legislation (eg Building Regulations or Health and Safety Regulations) does not mean the property could not be a dwelling for planning purposes”
I am surprise also by this reply because in its report the planning department says that the decision of this house being transformed into a single dwelling house has been taken at the balance of probabilities. However I do not understand why the planning department has not taken into account that if nobody can live in a house because breach of building regulation it is very likely that this property is not used as a single dwelling house.
I do not understand also why the planning department has not also taken into account that the fact that there is no door between the garage and the living parts of this property means also it is very likely that the panel of these two doors were not removed permanently and as a consequence this property is not a single dwelling house also for this reason.
I would like to know how to explain to the planning department that it is wrong
