Can anyone help me to make sense of the problems with my boiler PLEASE.
The boiler was installed about two years ago. since then it has had a problem every few months. It locks out and to start with can be restarted, the time between lockouts decreases over a couple of days until it will fire up and lock out a minute later or not fire up at all. Our plumber has showed us how to clean the photo cell. It all happened again over new year and an oil engineer serviced it and checked it all. Only one week later it happened again, the same engineer came out, cleaned the photo cell again (said there was a slight film on it) and removed the snorkel incase it was the flu. It is now a week later and we are again not able to get the boiler started.
The plumber says no point in him coming out because he doesn't know much about oil boilers!
The oil engineer says he has done everything he can and can't find anything to cause the problems and to contact Trianco.
Trianco say to contact the oil company because it is the Sulphur level in the oil and we should have an additive put in the oil.
The oil company say that the oil meets British Standards, that as it is only a week since it was all cleaned can't be the oil, and that as we have an aga (not in use because it stopped running last year after being fixed once already!)we should not put an additive in.
Can any one tell me how to sort this out. Is this a common problem with this boiler. I am recovering from chemotherapy and find it hard to keep warm even when the heating is working! Please help.
