Hi folks, (edit - sorry for the long post )
Ok heres the story...
Had the engineer out to service my boiler and also have a look at potential problem as there was a slight smell of oil and the fan was making a bit of a strange noise.
So he came out and had a look, said it needed a new pump, fan and expansion vessel. He also said that since theres water in the bottom of the tray, we wil be looking at a new boiler soon. (Nightmare)
Anyway, que sera sera..
So we discussed and he said that we should just get the pump replaced for now and see how it goes as its best to spend as little as possible on the boiler for now.
Pump replaced, fan still a bit noisy all working .....
Next, over the following week the fan starts making a worse and worse noise until I switched it off yesterdayday.. switched it back on today as I wanted to have a shower as I'd just got in from the gym and it just sat there and didnt make a sound, just a little click....
Called the eng out and they cant get out till tues which is understandable as its a busy time.
I guessed that the bearings on the fan/motor had finally seized and thought I wonder if I can at least get it working through the weekend, maybe take the fan apart and grease the bearings and the spindle.
So I stripped it down to the point where I open the fan cover plate, spin the fan and it seemed a bit stuck at first but when I moved it by hand it seemed to be ok. Put it all back together and switched it on and hey presto it sounded like it was working. Fan spinning etc etc..
But now, what it does is just sits there with the fan spinning in that state before the boiler actually fires, but it never fires, it never locks out either just hums away.
Like I say it was all working ok (if noisy) yesterday.
Any thoughts as to how I can get this thing fired up at least through the weekend.
thanks in advance,
Paula
PS Im quite handy with stuff and have fitted my own kitchen and bathroom so im not totally helpless apart from having run out of ideas
Just dont want you all thinking I dont know which end of a screwdriver to hold
thanks in advance,
Paula
