.but a good OFTEC person will usually be able to identify the bits from experience -
Doesn't sound like you've had a great time of it...you've paid out for pump,motor and control box (could nearly have got a new burner for similar money) - is the guy you've had out an oilman or a plumber that "does" oil, I've followed on after a few of these types who can happily clean a boiler year after year but come unstuck when it doesn't work.
Having said that the symptoms would indicate the motor needed replacing (you said it was noisy in 1st post) and subsequent posts indicated a problem with the control box.
I would've thought the flue problem would've presented itself at the service or after changing motor and control box. I'd suspect that the new pump hasn't been set correctly (did he use test equipment, pressure gauge?) - I would usually clean the flue, if accessible, when clearing a sooted boiler.
I'm sure at the moment you just want to leave it alone while it's workingbut if you need to get him back ask about the oil pump (they can go faulty I've had 3 in recent weeks having had none in 2 years, and for the oilmen they were RBL,RDB and a Danfoss L3 all on the van less than a year)
I really hope this is a closure for you, this has gone on long enough...however, I just wonder if the servicing guy actually set the pump pressure to the manufacturers spec, and did a smoke test and flue gas analysis afterwards......keep an eye on the vents of the balanced flue outlet and see if they turn black with soot sooner than usual.
John![]()
