I am tiling my bathroom floor and have decided to remove the old 20mm floorboards and replace with 25mm WBP ply, the only problem i have is a 3m steel rsj running down the centre of the bathroom. The joists have been run in the I section of the rsj and the floor boards are about 2mm higher than the top surface of the rsj.
Can i run the ply either side of the rsj and infill with a thinner piece or would i be better off chiselling out a section of ply (18mm) to allow a perfect fit over the rsj. I only ask this as i don't know whether there will be any lateral movement either side of the rsj that could break any tiles that span that particular area. Any advice would be welcome.
