Trimmers to rooflights
1 Dec 2019
i am looking to install a 3000mm x 2000mm roof light in my extension roof.
the roof structure is being cut in the next few weeks. should the trimmers around the roof light be double or triple timbers? I have seen both used but what dictates which to use?
Trimmers don’t carry much weight generally - it’s the full length beams which carry the load -if you are referring to them then span and depth are key factors.
sometimes carpenters do double or triple joisting to match the beams - so doing the upstands ets is the same all round
Thanks. The full length timbers are spec'd as 8x2's. Should i double these up?
It needs a structural engineer to advice really - hopefully Tony will see your post.
the total span is needed to answer.
Span between the steels that the roof light sits on is 3.4m
