What method are you using to level the floor that requires skirting undercut?
Once the tile is lifted then we will be using a self leveling latex which we anticipate will add approx 5-10mm and as the tile is currently tight to the skirting then there will be no room to insert it back under the skirting.What method are you using to level the floor that requires skirting undercut?
You could just cut tiles to meet skirting .
No chance of breaking any tiles cause they will all be lifted before any work to remove the skirting beginsI would take the skirtings off rather than increase the risk of breaking the tiles.
Yes we can once the floor has been levelled.If you try to cut along the bottom edge of the skirting how will you ensure a straight cut You can't use the floor level as your guide.
Nope, from last experience they are held on by wooden pegs that are fixed back into the brick work so by removing the skirting it damages as far back as the brick.The skirtings may be just stuck to the plaster surface
Well at least intermediate experience but that's what this is all about, finding a better way to do something.... because of inexperience...
Then I'd suggest that you add a layer of 4 or 6mm ply screwed on 150mm centres before you add the SLC.Once the tile is lifted then we will be using a self leveling latex which we anticipate will add approx 5-10mm
Thanks for the adviceThen I'd suggest that you add a layer of 4 or 6mm ply screwed on 150mm centres before you add the SLC.
FYI I’ve reported that listing to eBay.
Unfortunately they don’t have a box in which to provide a description of the danger, so they will probably not appreciate the issue.
I've never understood why it was permitted to sell angle grinders with lock-on switches.Anything running at 10,000 to 12,000 rpm needs to be treated with respect - and is not something you want to stand behind. Wonder if they'll ever ban lock-on switches on angle grinders and make is all go to paddle switches?
