looking at the picture you put up , I have every doubt that 6mm Glass has been used .... looks like 20mm Warm edge Spacer to me , so a 28mm Unit, which is std in most UPVC. And honestly with those size of frames I don't see why they used 6mm. I can only assume they were going to use 4/8/4/8/4 triple glazing , which would give literally no benefit over a 28mm A rated Unit, in fact running it through , a std 28mm Unit would give a u value of 1.2 ( 28mm unit using Pilkington K softcoat ) , 6mm glass unit , a u value of 1.2( 28mm Unit , using Pilkington K softcoat ) , and triple glazing ( 28mm unit using Pilkington K SOftcoat on one pane of the three ) u value 1.3. so yes 6mm offers a marginal better performance than triple glazed , but not double as cavity is reduced. And as i started this answer on , thats a 20mm spacer bar in that unit from what I can see , so I have very serious doubts thats 6mm glass, as the unit thickness would be 32mm, which std upvc isn't set up for
Disclaimer ... all the above U - values are calculated with Pilkington OPtifloat/ Pilkington K S , on 90 % fill of ARgon ( which will leak out! ) . There are other options of glass which could alter the U values. You would need the exact ' make up ' of the sealed unit to confirm the U value.
