they said they could if i wanted it but as it is extra cost not to bother i want the best thermal window i can buy cost is not a problem , quality is what i want
Triple glazing needs to be at least a 44mm unit for any benefits but they are negligible for the extra money it costs.
More seals on the units are more seals that can fail and mist up which will lead to more frequent replacements that cost more.
The reduced air gaps in the glass can increase noise transmittance.
The frames lose more heat than double glazed units so in theory better frames would be the way to go.
Personally I also worry about about the longevity of the hinges with the extra weight.
I think its more of a sales gimmick (profit making tool) for now in this country and more suited to colder environments, Although the technology improvements are coming thick and fast at the moment so some day soon I will probably be recommending it myself.
