Hi, I have a Potterton EP3000 programmer about 15yrs old. My problem is that when you push the manual override to bring the heating on it blows the 3amp fuse in the spur, if you bring the heating on via clock it also blows same fuse? Central heating not used over summer? The hot water is fine? Is it the programmer shorting or something else causing it to blow fuse ?
Cheers
Ray
Cheers
Ray
