Had an electrician visit this afternoon. He did lots of testing and found that one of the garden lighting circuits had an issue. This circuit comprises 6 LED flush fitting wall lights and on removing the fronts of of them I was surprised to see lots of soil and an ants nest in one of them! Due to lack of space, each fitting is connected using a plastic connector wrapped in insulation tape, but a couple of the connectors showed signs of deterioration due to damp. So, I plan to clean up the fittings and replace the connectors with something else (wago?) and attempt to make them water resistant with insulation tape. I'll also seal the cable entry gland at the back of the fitting with silicon although there's no sign that this is how moisture is getting into the fitting.
He also told me the double switch in the house used to turn the lights/water pump on/off has a shared neutral and ideally, the switches should be separated out into two fused spurs.
He also pointed out my plastic consumer unit doesn't meet current regulations and the mcb/rcd layout would be better replaced with rcbo's and a surge protector All true, but also very expensive to do!
