You mention you have batons screwed to the wall level with the pour and have notched wood to tamp down. Am I naive in thinking you can just drag your wood over the top along the levelled batons to avoid tamp lines?
Please do - I'll be doing this in a couple of months.One thing I will promise to do is report back here when this is done to either confirm its an absolute ball ache or explain how I got on for anyone else considering doing it !
Why? Why don't you plan for a screed FFS!Please do - I'll be doing this in a couple of months.
Just another comment - it's quite a lot of effort tamping down wet concrete with a batten. Ideally you need to be able to execute a side to side sawing motion, moving the concrete towards you as you flatten it. You're also tamping it downwards to get rid of air and knock the aggregate down from the surface.That was the idea but not sure as I've never done it before, I'll let ya know
this is your best advice so far,You bull float straight after its been laid. Then a Fresno blade after about 4 hours if your not power floating it.
To get the concrete the necessary level for ffl is not rocket science just set your guides at the correct height , ffl minus floor finish.
Make sure you don't add any additional water to the mix to make it flow easier, don't float it with water on the surface, you can bull float it as that leaves the surface open.
You should fairly easily get a good enough finish to tile over with some time and enough help to place it so you are not too tired to finish it off.
Will be screeding over the UFH, but keen to get a flat as possible slab to lay insulation on.Why? Why don't you plan for a screed FFS!
