Thanks doitall. Yes, the bypass valve is on the heating side only. Therefore, I will consider, as you suggest, installing a wireless room sat in the lounge although I understand this may need need some wiring adjustments at the boiler or at the programmer to get it to work. Any suggestions where I might find advice on how to replace a wired stat with a wireless one. Also would it be better to buy a combined stat/ programmer and disconnect both the existing room stat and airing cupboard programmer?
