Trying to find an MK cooker swtich that's no longer produced
your probably right rf, i would rather do this anyway but the homeowner tiled the wall abt a year ago and im trying to avoid the mess!! :evil:
Is it surface mounted? I only remember ever seeing those MK ones on surface. I don't think they did a flush mount version.
I think crabtree used to do one a similar size which might still be available and might fit as a replacement. I'll have a look.
hmmmm, might have such a beast sat here.
145mm wide, 118mm high, mk cooker connection unit with socket to the right. red toggle switch (as the current Logic CCU, but red)
no part numbers that I can see, other than a patent number 1024225
possible part number under the earth bar, 7445, numbers in similar font on the back box and cover 7475 and 7478 respectivly
cant upload a photo atm as Im working away this week, can sort out a photo sunday though if the measurements seem ok.
RF took the words out my mouth;
Look online on the Crabtree catalouge
45A DP COOKER CONTROL UNITS l
BS 4177 & BS 1363 PACK QTY
45A DP main switch and 13A switch socket 1 4520/1
outlet. Faceplate marked ‘cooker’
45A DP main switch and 13A switch socket with 1 4520/31
neon indicators. Faceplate marked ‘cooker’
Dimensions 168mm x 114mm
Mounting boxes 9052 surface or 9338/GV flush[/url]
