I took off a radiator to do some decorating, which was fine, but I must have twisted one of the valves as I loosened it as it started to leak from the nut where it joins to the pipe.
The leak gets better if I tighten the nut but doesn't completely stop (a small drip will form over about ten minutes) - I figure that I just need to remove the valve and add new tape to the olive (and/or replace the olive) - this is fine, I've done this many times on the water system, but never on the heating system.
With the heating switched off, I'm still getting water coming through if I open the valve.......how do I switch this off??
In the airing cupboard there is a stop cock (with no hadle on it) just above the water pump.......there is also a second stop cock with a red handle on it - but this looks as if it lets hot water into the hot water cylinder.
Should I turn off the stop cock coming from the pump??.......I didn't want to try it incase it's set to a specific position.
Pic here...
https://dl.dropbox.com/u/20678785/heating.jpg
thanks,
Darren
Pic here...
thanks,
Darren
