Hi All,
I have a couple of questions that I need cleared up. I moved into a flat 18 months ago and have noticed that in high winds or heavy rain the signal goes from the TV. I assume this is most likely from the aerial moving/ bad connection somewhere?
I have spoken with the management company and they have said they have received no other complaints and that it must be my own connection. Short of getting someone out to look at it what can I do? What can I look for?
I have removed the wall plate and noticed there are 2 cables attached (I only have one socket). The wall plate appears to be un-shielded. I have thought about replacing this but not sure what socket i can use as all the other appear to be for only 1 cable. What do you recommend?
Thank you in advance
R
R
