Tv Mount into osb
29 May 2006
Essex
Hi there, just had a garden room built and they reinforced a section for me with osb pattress to wall Mount a 43 inch tv. Just on a flat mount, two feet wide, no extending arms or whatever.
Probably about 15mm thick osb, directly behind plasterboard. Gap behind it to insulation.
Will about 8 5x50mm wood screws do the trick? I may be able to get a couple of them into a stud somewhere near the middle if I can locate it!
How heavy is the TV?
Most are amazingly light nowadays
i bung 40-50” TVs onto ply/MDF/chip with a couple of screws
That’s for exhibition work so they are flat onto the wall with no extra leverage.
I mean 15mm OSB has pretty decent pull-out for a tv bracket. I reckon you'd be fine.
