hi folks
I have recently bought our first house, an old Victorian house with a 36m2 living roomer/diner. In the front of the living room stands a “fake” studded chimney stack, there used to be a chimney here but then they decided to knock it out from the ground up and then supported correctly in the loft space. Anyway for whatever reason they decided to reconstruct the fireplace some years later using a stud and plywood approach, no plaster.
With the above in mind we are wanting to mount the tv on this fake chimney breast albeit it unconventionally quite low down which shouldn’t be an issue but just wondered whether it’s safe enough just to rely on the ply alone holding a 50” lcd screen on brackets or whether I should rethink the whole approach. I can see behind the construction from the fake opening below and it is single sheets of ply mounted to a damn solid frame.
Thanks for any assistant
