- Joined
- 8 Sep 2020
- Messages
- 20
- Reaction score
- 0
- Country
In the process of purchasing a LG 55CX OLED and looking to mount this on a cantilever mount. I've been recommended Sanus mounts, but none of their mounts seem to say they’re suitable for mounting on a brick wall
The chimney is unused (and the alcoves either side are too small for the 55") so we were thinking this makes the most sense. There is plaster over the fireplace (a thin skim of Gypsum over the original lime - but no laths). The Chimney opening is supported by an iron bar and a course of soldier bricks, but is only one brick thick (just over 110mm thick).
Just wondering if anyone has any advice on how to safely mount a TV onto this kind of wall without me pulling my chimney breast down? Has anyone done this before?
Should I anchor to the brick? If so what is the best option? Should I avoid a cantilever mount (I’ve heard these can put more stress on the wall)
I was also thinking of drilling a 32mm hole with a core drill to run the cables through to the inside of the chimney and out the side to the alcove. Has anyone done anything similar this?
Also attached an image from the LG AR app to show rough placement thoughts-in terms of height it’s just slightly above eye line so shouldn’t be too bad on the neck!
Thanks!
Thanks!
