hi iam getting a new conservatory and just wondered the best way to put a new tv point in i have the coaxe cable where do i run it and how hope it makes sense thanx for any help
No, because if you connect 2 cables to your ariel you will split the signal & adversely affect the picture quality on both TVs as securespark said you will need to instal an amp.
ahh i thougth he was tellin me three ways of doing aerial/splitter/amp! could any one show me a diagram from the aerial down to the tv point thanx for any help given
There are a few ways of doing it, if you look at the various amps available in the shops, they will have a diagram of how they need to be connected. Some have a mast head amp that you fit to the ariel & a power supply behind the tv, some go in the loft & split off down to each room etc. You need to decide what is best for your needs.
