L
LondonChap
A neighbour is running direct burial cable from the house to his outside lights. The lights will be inset in a concrete wall. The direct burial is to the first light in the wall. The rest of the lights in the wall are to be daisy chained from that. The issue is using 1.5mm twin and earth from light to light buried about 10mm below the surface not in conduit, buried directly. Because of re-bar it is not possible to go deeper. This will be on an RCD. In internal installations a cable can be less than 25mm from a wall surface as long as it is on an RCD. I can't see any difference here.
What do others think of this? Sensible replies only please.
