L
LondonChap
SimonH2: It is bouncing ideas around to get a cost-effective solution. Disabling an RCD and using that as an isolator switch means that bank can be isolated while the other RCD bank is on. One main switch will still be there. The idea would be to fit a DP RCBO so the garden side is totally isolated if switched off or it trips. They are available.
sparkwright: 10mm conduit may be suitable when a chase is cut out to see.
bernardgreen: the wall has just been built and is 12 to 16" thick, filled with rebar which is driven into clay beneath the foundations. A cable chase will not weaken this structure at all.
mattylad: The chases will be vertical and an RCD'd circuit.
securespark: If it is lighting running off 1.5mm cable and second small CU is fitted what is wrong with using 2.5mm cable, which is way oversized for the load anyhow? Why greatly oversize with 4mm or whatever? I know a junction box for the tails can be fitted, which is the right thing for heavy cable, but one for 2.5mm? It can be jumped off the main CU switch.
