Can anyone help, I need to wire into my heating system a second hot water tank with a tank stat and a 3 port valve Can anyone help with wiring. The problem I have is that when the original tank stat switches off this sends a live to the original 3 port valve, as this has a wire from the programmer which is live when the HW is switched off, when the stat on the new hot water tank calls for heat it starts the boiler and pump although the HW is in the off position on the programmer, I think the live from the HW off is feeding back through the first tank stat (SAT) and (COM). I have tried to fit diode between first tank stat (SAT) and (COM) wires as I thought it would not let the current flow backwards, but that didn't work. not sure if I used the correct diode. any help would appreciated.
Regards
Perry
Regards
Perry
