I wonder if an RF tank sensor would not be better than the pipe sensor as that seems to be the major problem?
What do you mean by an RF tank sensor please?
Radio Frequency - wireless.
I don't know.
I am quite often unsure of what Eric has in mind.
I am also unsure how your system is different than a conventional set-up and why it requires any relays
I think I could solve the pipe stat problem with another (non-latching) relay, so that instead of the charge pump powering the ZV and EP and being wired in parallel to them, it would switch a relay that would allow power through from the programmer to the ZV and EP. The Charge pump would be powered from an independent permanent source that would have to be switched by another (oh no) relay from the programmer and this power would go through the pipe stat before reaching the charge pump.
But presumably it is possible to have a switching relay that can output two independent supplies?
Is this where you are going wrong?
The (charge) pump should not power anything; it should be powered by what ever device is calling for heat in the situation.
I am confused by your original post.
Please answer me this; what happens and comes into operation when the programmer is calling for Hot Water?
Where I see a problem is for the system to know if the water outside is hot or cold?
Although a sensor on the pipe can sense when the hot water has run out it can't detect if there is hot water there before it starts pumping.
